Toshiba Satellite C855D-S5109 Hard Drive Replacement
  1. Toshiba Satellite C855D-S5109 Hard Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C855D-S5109 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the laptop over so the bottom is facing up.
  2. Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the two lock tabs on the battery to the open position.
  3. Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 3, image 1 of 3 Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 3, image 2 of 3 Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 3, image 3 of 3
    • While still holding the lock tabs outward, use your hand to grab the top of battery and pull up.
    • Remove the battery.
  4. Toshiba Satellite C855D-S5109 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 Toshiba Satellite C855D-S5109 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Use the Phillips #00 screwdriver to unscrew the captive screw on the L-Shaped panel.
    • Remove the L-Shaped panel.
  5. Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C855D-S5109 Hard Drive Replacement: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the screw(s) securing the hard drive to the laptop case.
    • Carefully pull the tab on the hard drive to detach the connecting wire to the right of the hard drive.
    • Remove the hard drive.
Rebeca Carrillo
87 Reputation
1 Guide authored
Casper College, Team 1-3, Lareau Fall 2021 Member of Casper College, Team 1-3, Lareau Fall 2021
CASC-LAREAU-F21S1G3
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 176
