Toshiba Satellite C675-S7106 Wireless Card Replacement
  1. Toshiba Satellite C675-S7106 Wireless Card Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 2, image 1 of 2 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 2, image 2 of 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 Wireless Card Replacement, Keyboard: step 3, image 1 of 1
    • Open the laptop with the screen facing you, as if to use it.
  4. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 4, image 1 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 4, image 2 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 4, image 3 of 3
    • Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
    • Pull up on the rest of the plastic bar to remove it.
  5. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 5, image 1 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 5, image 2 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 5, image 3 of 3
    • Remove the four 2.5mm M2 screws above the keyboard using a PH0 screwdriver.
  6. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 6, image 1 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 6, image 2 of 3 Toshiba Satellite C675-S7106 Wireless Card Replacement: step 6, image 3 of 3
    • Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
    • Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
  7. Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: step 7, image 1 of 2 Toshiba Satellite C675-S7106 Wireless Card Replacement, Wireless Card: step 7, image 2 of 2
    • Underneath the keyboard, gently disconnect the black and white wires on the right of the wireless adapter using a thin plastic spudger.
    • Be sure to properly re-connect the two wires during assembly, perhaps using the back end of the spudger to ensure that the connection is made.
  8. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 8, image 1 of 1
    • Unscrew the one 3mm screw in the top-left corner of the wireless adapter using a PH0 screwdriver.
  9. Toshiba Satellite C675-S7106 Wireless Card Replacement: step 9, image 1 of 1
    • Lift the card up and to the right to remove it from the device.
Dinis Valcorba
292 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 269
