Toshiba Satellite C675-S7106 CMOS Battery Replacement
  1. Toshiba Satellite C675-S7106 CMOS Battery Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop over, so that the "top" of the laptop is against your working surface.
    • Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
  2. Toshiba Satellite C675-S7106 CMOS Battery Replacement: step 2, image 1 of 2 Toshiba Satellite C675-S7106 CMOS Battery Replacement: step 2, image 2 of 2
    • On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
    • On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
  3. Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: step 3, image 1 of 2 Toshiba Satellite C675-S7106 CMOS Battery Replacement, CMOS Battery: step 3, image 2 of 2
    • Rotate the laptop so that the battery cavity faces away from you.
    • Unscrew the single PH0-head screw connecting the center panel to the laptop.
    • This screw does not need to be completely removed, as it's permanently attached to the device.
    • Using a plastic spudger, unclip and remove the panel from the device.
  4. Toshiba Satellite C675-S7106 CMOS Battery Replacement: step 4, image 1 of 1
    • Using a thin pry tool, gently remove the battery from its socket.
Joshua Steakelum
451 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 282
