Toshiba Satellite C655-S5142 RAM Replacement
  1. Toshiba Satellite C655-S5142 RAM Replacement, RAM: step 1, image 1 of 2 Toshiba Satellite C655-S5142 RAM Replacement, RAM: step 1, image 2 of 2
    • Ensure that your laptop is turned off and the battery has been removed
    • Flip over your laptop where the battery side is closest to you.
  2. Toshiba Satellite C655-S5142 RAM Replacement: step 2, image 1 of 2 Toshiba Satellite C655-S5142 RAM Replacement: step 2, image 2 of 2
    • Unscrew the singlular screw in plate with a Phillips #1 screwdriver.
    • The screw does not come all the way out of the plastic plating, instead there is a protector that keeps it in place for you even when fully unscrewed.
  3. Toshiba Satellite C655-S5142 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite C655-S5142 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite C655-S5142 RAM Replacement: step 3, image 3 of 3
    • To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
    • Once pushed outwards, the first RAM stick will pop up at an angle
    • After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
Hunter Gonsalves
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 212
