Toshiba Satellite C655-S5142 Keyboard Replacement
  1. Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: step 1, image 1 of 3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: step 1, image 2 of 3 Toshiba Satellite C655-S5142 Keyboard Replacement, Keyboard: step 1, image 3 of 3
    • Unplug your computer, and make sure that it is shut off before starting
    • Using the metal spudger, gently insert it under the plastic covering slowly easing it up until the screws are revealed.
    • The plastic covering will make clicking sounds when being removed this is normal, you are not breaking it.
  2. Toshiba Satellite C655-S5142 Keyboard Replacement: step 2, image 1 of 2 Toshiba Satellite C655-S5142 Keyboard Replacement: step 2, image 2 of 2
    • Using a phillips head screwdriver, unscrew each of the four screws.
  3. Toshiba Satellite C655-S5142 Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite C655-S5142 Keyboard Replacement: step 3, image 2 of 2
    • Gradually lift the keyboard up, it will reveal the connector cable.
    • Do not pull the keyboard away too hard, this may damage the connector.
  4. Toshiba Satellite C655-S5142 Keyboard Replacement: step 4, image 1 of 2 Toshiba Satellite C655-S5142 Keyboard Replacement: step 4, image 2 of 2
    • With the keyboard resting up, pull the tabs to disconnect the cable from the laptop.
Alex Kozlowski
244 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 336
