Toshiba Satellite C655-S5142 Hard Disk Drive Replacement
  1. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: step 1, image 1 of 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement, Hard Disk Drive: step 1, image 2 of 2
    • Unplug your computer, and make sure that it is shut off before starting.
    • Flip over your laptop, making sure the hard drive is facing you.
  2. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: step 2, image 2 of 2
    • Using a Phillips head screwdriver, remove the one screw holding the backplate on.
  3. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: step 3, image 1 of 2 Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: step 3, image 2 of 2
    • With a Phillips head screwdriver remove the final screw holding the hard drive in place.
  4. Toshiba Satellite C655-S5142 Hard Disk Drive Replacement: step 4, image 1 of 1
    • To remove the hard drive, lift up the plastic tap attached to it and slowly pull up using your other hand as support.
Alex Kozlowski
244 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 327
