Toshiba Satellite C55D-B5310 Hard Drive Replacement
  1. Toshiba Satellite C55D-B5310 Hard Drive Replacement, CD/DVD Drive: step 1, image 1 of 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  2. Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 2, image 1 of 2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 2, image 2 of 2
    • Slide the CD/DVD Drive out of the laptop.
  3. Toshiba Satellite C55D-B5310 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the thirteen 7 mm screws that secure the bottom cover.
  4. Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 4, image 1 of 2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you start from a corner, and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  5. Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 5, image 1 of 2 Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 5, image 2 of 2
    • Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
  6. Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 6, image 1 of 3 Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 6, image 2 of 3 Toshiba Satellite C55D-B5310 Hard Drive Replacement: step 6, image 3 of 3
    • Remove the hard drive from the blue rubber mount.
6 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 44
All Time: 3,182
