Toshiba Satellite C55D-B5206 Trackpad Replacement
  1. Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C55D-B5206 Trackpad Replacement, Battery: step 1, image 2 of 2
    • Turn the laptop upside down so the battery faces upwards.
    • Remove the two 7 mm Phillips screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 2, image 1 of 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: step 2, image 2 of 2
    • Place both thumbs on the outside edges of the battery that meet the device.
    • Push the battery out and away from the laptop.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Trackpad Replacement, Back Casing: step 3, image 1 of 1
    • Remove the thirteen 7 mm Phillips #1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 4, image 1 of 1
    • Starting at the center, insert a spudger into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook six clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 5, image 1 of 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: step 5, image 2 of 3 Toshiba Satellite C55D-B5206 Trackpad Replacement: step 5, image 3 of 3
    • Use your fingers to finish removing the casing from the device.
  6. Toshiba Satellite C55D-B5206 Trackpad Replacement, Trackpad: step 6, image 1 of 1
    • Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
  7. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 7, image 1 of 1
    • Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
    • Gently pull the blue ribbon cable free.
  8. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 8, image 1 of 1
    • Use a small Philips screwdriver to remove the screw shown.
  9. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 9, image 1 of 2 Toshiba Satellite C55D-B5206 Trackpad Replacement: step 9, image 2 of 2
    • Push the two gray tabs out on the large wire plug shown.
    • The tabs only need to be pressed out a few millimeters, not all the way.
    • The plug can now be carefully pulled out.
  10. Toshiba Satellite C55D-B5206 Trackpad Replacement: step 10, image 1 of 1
    • Gently lift the trackpad to remove it.
Elaine Butler
265 Reputation
2 Guides authored
IUPUI, Team 1-2, Beck Spring 2022 Member of IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 143
