Toshiba Satellite C55D-B5206 RAM Replacement
  1. Toshiba Satellite C55D-B5206 RAM Replacement, RAM: step 1, image 1 of 1
    • First, flip the laptop over and use the J1 screwdriver (in the iFixit tool kit) to unscrew the 15 screws indicated in the picture.
    • Make sure to put your screws in a safe place to make sure they do not get lost.
  2. Toshiba Satellite C55D-B5206 RAM Replacement: step 2, image 1 of 1
    • Once you take the screws out, take the battery off; it should slide off easily.
  3. Toshiba Satellite C55D-B5206 RAM Replacement: step 3, image 1 of 1
    • Next, move around the edges of the computer with the metal spudger prying off the casing. You should hear clicks as you do this; this is not the casing breaking, it is just popping off.
  4. Toshiba Satellite C55D-B5206 RAM Replacement: step 4, image 1 of 1
    • Then, carefully take off the back casing of the laptop and set it aside.
  5. Toshiba Satellite C55D-B5206 RAM Replacement: step 5, image 1 of 1
    • This is where the RAM is located that you will be replacing.
  6. Toshiba Satellite C55D-B5206 RAM Replacement: step 6, image 1 of 1
    • There are two clips holding the RAM in place.
    • You will need to hold both of them back to be able to safely remove the RAM.
    • Use plastic spudgers, as the metal spudgers pictured here are not ESD-safe.
  7. Toshiba Satellite C55D-B5206 RAM Replacement: step 7, image 1 of 1
    • Gently remove the RAM and insert replacement.
2 other people completed this guide.
One Comment
This guide was done wonderfully. My critique for your group is to be more specific with the direction of how to pull/place the components of the device. Your instructions were simple, yet clear. Great work.
Dan Hartzell - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 539
