Toshiba Satellite C55D-A5201 Keyboard Replacement
  1. Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement, Battery: step 1, image 3 of 3
    • Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
  2. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 2, image 1 of 1
    • Release the locking mechanism by switching the left slider to the left.
  3. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 3, image 1 of 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 3, image 2 of 2
    • Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
  4. Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Toshiba Satellite C55D-A5201 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Remove the 3mm Phillips #00 screw holding the keyboard in place.
  5. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 5, image 1 of 1
    • Flip over and open the laptop.
  6. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 6, image 1 of 1
    • Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
    • Lift the plastic opening tool up until the corner of the keyboard is detached.
    • You will hear a popping sound as each portion of the keyboard becomes detached.
  7. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 7, image 1 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 7, image 2 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 7, image 3 of 3
    • Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
    • Continue up the left side of the keyboard.
  8. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 8, image 1 of 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 8, image 2 of 2
    • Lift the keyboard up by grabbing it on both sides.
    • Set the keyboard against the laptop screen.
  9. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 9, image 1 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 9, image 2 of 3 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Using tweezers, push up the two black switches on either side of the ZIF connector.
  10. Toshiba Satellite C55D-A5201 Keyboard Replacement: step 10, image 1 of 2 Toshiba Satellite C55D-A5201 Keyboard Replacement: step 10, image 2 of 2
    • Pull out the ZIF connector to release the keyboard.
    • Lift up the keyboard.
13 other people completed this guide.
Kari Byrd
614 Reputation
1 Guide authored
Baylor, Team 6-5, Shaver Spring 2015 Member of Baylor, Team 6-5, Shaver Spring 2015
BU-SHAVER-S15S6G5
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 5,824
