Toshiba Satellite C55D-A5108 RAM Stick Replacement
  1. Toshiba Satellite C55D-A5108 RAM Stick Replacement, Battery: step 1, image 1 of 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 RAM Stick Replacement: step 2, image 1 of 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 RAM Stick Replacement: step 3, image 1 of 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 RAM Stick Replacement, RAM Stick: step 4, image 1 of 1
    • Use a Phillips #0 screwdriver to unscrew the memory cover.
  5. Toshiba Satellite C55D-A5108 RAM Stick Replacement: step 5, image 1 of 1
    • Carefully hold the edges of the RAM and remove the stick.
  6. Toshiba Satellite C55D-A5108 RAM Stick Replacement: step 6, image 1 of 1
    • Line up the new stick of RAM with the gold contacts facing the slot and evenly push the new stick into the same slot which you removed the old stick.
Geoffrey Souza
327 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 252
