Toshiba Satellite C55D-A5108 Keyboard Replacement
  1. Toshiba Satellite C55D-A5108 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Flip over the device so that the model stickers are facing up.
  2. Toshiba Satellite C55D-A5108 Keyboard Replacement: step 2, image 1 of 1
    • Move the right notch to the unlock position by sliding it to the right.
  3. Toshiba Satellite C55D-A5108 Keyboard Replacement: step 3, image 1 of 1
    • Hold the left notch in an unlocked position with one hand and use the other hand to slide the battery out.
  4. Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: step 4, image 1 of 2 Toshiba Satellite C55D-A5108 Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Open the device so that the keyboard is visible.
    • Slip the wide tip of the spudger underneath the Enter key on the keyboard.
  5. Toshiba Satellite C55D-A5108 Keyboard Replacement: step 5, image 1 of 1
    • Slowly slide the spudger along the perimeter of the keyboard in a clockwise manner until you’ve reached the top left corner.
    • Lift the keyboard at an angle.
    • Be aware to not lift the keyboard too forcefully as to not damage anything.
  6. Toshiba Satellite C55D-A5108 Keyboard Replacement: step 6, image 1 of 2 Toshiba Satellite C55D-A5108 Keyboard Replacement: step 6, image 2 of 2
    • Use the pointed tip of the spudger to open the notches on the ribbon cable directly attached to the device.
    • Pull the connector out of its slot and lift the keyboard out of the device.
Michael Medeiros
150 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 245
