Toshiba Satellite C55-B5302 laptop Memory chip (RAM) Replacement
  1. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: step 1, image 1 of 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Battery: step 1, image 2 of 2
    • Flip laptop upside down so you can see the screws.
  2. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 2, image 1 of 2 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 2, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
  3. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 3, image 1 of 1
    • Pull the battery from the back of the laptop for removal from the laptop.
  4. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): step 4, image 1 of 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): step 4, image 2 of 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement, Memory chip (RAM): step 4, image 3 of 3
    • Remove the remaining thirteen 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
    • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
    • Expect to hear popping as you pull the back panel off.
  5. Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 5, image 1 of 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 5, image 2 of 3 Toshiba Satellite C55-B5302 laptop Memory chip (RAM)  Replacement: step 5, image 3 of 3
    • Push down on the two clips holding the RAM chip in place.
    • Pull the RAM chip up slightly and out away from the connection to remove.
0 Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,105
