Toshiba Satellite C55-B5200 Hard Disk Drive Replacement
  1. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Battery: step 1, image 1 of 1
    • Turn the laptop off and remove all sources of power.
    • Flip the laptop over so that way the bottom is facing towards you.
    • Remove the two 6.6mm Phillips #0 screws from the battery.
  2. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement: step 2, image 1 of 1
    • Pull the battery out of the laptop.
  3. Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 1 of 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 2 of 3 Toshiba Satellite C55-B5200 Hard Disk Drive Replacement, Hard Disk Drive: step 3, image 3 of 3
    • Remove the two 4.6mm Phillips #0 screws from disk drive.
    • Lift the disk drive and pull out to remove.
5 other people completed this guide.
Pablo Andrade
1,081 Reputation
7 Guides authored
USF Tampa, Team S3-G1, Nance Spring 2018 Member of USF Tampa, Team S3-G1, Nance Spring 2018
USFT-NANCE-S18S3G1
4 Members
22 Guides authored
One Comment
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
stevesd619 - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 24
All Time: 4,496
