Toshiba Satellite C55-B5101 RAM Replacement
  1. Toshiba Satellite C55-B5101 RAM Replacement, RAM: step 1, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement, RAM: step 1, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement, RAM: step 1, image 3 of 3
    • Use a Phillips #1 screwdriver to remove fifteen 7 mm screws from the back case.
    • Save all fifteen 7 mm screws in a safe place. The screws will be used in reassembly.
  2. Toshiba Satellite C55-B5101 RAM Replacement: step 2, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 2, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 2, image 3 of 3
    • Use your thumbs to push the external battery out from the edge of the laptop.
    • Keep the battery in a safe place, as it will be needed for reassembly.
  3. Toshiba Satellite C55-B5101 RAM Replacement: step 3, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 3, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 3, image 3 of 3
    • Use an opening tool in the seam between the top and bottom case to begin prying the back case from the device.
    • Continue around the perimeter of the laptop and release any clips with the opening tool.
    • Pull off the back panel from the base starting on one side and working your way around.
    • Set the back panel aside.
  4. Toshiba Satellite C55-B5101 RAM Replacement: step 4, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 4, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 4, image 3 of 3
    • Simultaneously pull the tabs on each side of the RAM stick away from the center.
    • Once released the RAM stick should pop out at a 45 degree angle, making it easy to grasp and slide out.
  5. Toshiba Satellite C55-B5101 RAM Replacement: step 5, image 1 of 2 Toshiba Satellite C55-B5101 RAM Replacement: step 5, image 2 of 2
    • Gently slide the RAM stick out from the socket.
    • The stick should slide out easily.
    • Slide the RAM stick out at the released angle. Pulling it at an odd angle or too forcefully may risk bending the pins in the socket and damaging the laptop.
  6. Toshiba Satellite C55-B5101 RAM Replacement: step 6, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 6, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 6, image 3 of 3
    • Hold the clips out a few millimeters while placing the new RAM stick back into.
    • Be sure the RAM is lined up properly with the connector to avoid damaging the pins.
  7. Toshiba Satellite C55-B5101 RAM Replacement: step 7, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 7, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 7, image 3 of 3
    • Press down on the back of the RAM until a "click" sound is heard.
    • The new stick is now in place.
    • The new RAM stick should lie flat.
  8. Toshiba Satellite C55-B5101 RAM Replacement: step 8, image 1 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 8, image 2 of 3 Toshiba Satellite C55-B5101 RAM Replacement: step 8, image 3 of 3
    • Reassemble the back case.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 23
All Time: 152
