Toshiba Satellite C55-A5310 RAM Replacement
  1. Toshiba Satellite C55-A5310 RAM Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-A5310 RAM Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-A5310 RAM Replacement, Battery: step 1, image 3 of 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 RAM Replacement, RAM: step 2, image 1 of 2 Toshiba Satellite C55-A5310 RAM Replacement, RAM: step 2, image 2 of 2
    • Remove one JIS #000 screw.
    • This screw does not come out all the way, but you will still be able to open the back panel.
  3. Toshiba Satellite C55-A5310 RAM Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to pry the panel open. Be sure to do this on all four sides. Then the panel will lift off.
  4. Toshiba Satellite C55-A5310 RAM Replacement: step 4, image 1 of 3 Toshiba Satellite C55-A5310 RAM Replacement: step 4, image 2 of 3 Toshiba Satellite C55-A5310 RAM Replacement: step 4, image 3 of 3
    • Take the nylon spudger, and push the prongs so that it releases the RAM.
  5. Toshiba Satellite C55-A5310 RAM Replacement: step 5, image 1 of 3 Toshiba Satellite C55-A5310 RAM Replacement: step 5, image 2 of 3 Toshiba Satellite C55-A5310 RAM Replacement: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
Kari Rodgers
482 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 335
