Toshiba Satellite C55-A5310 Fan Replacement
  1. Toshiba Satellite C55-A5310 Fan Replacement, Battery: step 1, image 1 of 3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: step 1, image 2 of 3 Toshiba Satellite C55-A5310 Fan Replacement, Battery: step 1, image 3 of 3
    • Push the left tab with your left hand.
    • Then push the right tab with your right hand.
    • While your right hand is still pushing, remove the battery with your left hand.
  2. Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: step 2, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement, Optical Drive: step 2, image 2 of 2
    • Remove one screw with a JIS #000 screwdriver.
    • This screw does not come completely out, but you will still be able to get the panel off.
  3. Toshiba Satellite C55-A5310 Fan Replacement: step 3, image 1 of 1
    • Use the plastic opening tool to pry open the back panel. Make sure to loosen all four sides then lift up.
  4. Toshiba Satellite C55-A5310 Fan Replacement: step 4, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement: step 4, image 2 of 2
    • Remove a .5mm screw with a JIS #000 screwdriver.
  5. Toshiba Satellite C55-A5310 Fan Replacement: step 5, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement: step 5, image 2 of 2
    • Using a plastic opening tool, pry open the disk drive. Once it has loosened it will pull out.
  6. Toshiba Satellite C55-A5310 Fan Replacement, Fan: step 6, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement, Fan: step 6, image 2 of 2
    • Take a nylon spudger and push the prongs so that it releases the RAM.
  7. Toshiba Satellite C55-A5310 Fan Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Once the RAM has lifted, use tweezers or fingers to pull it out.
  8. Toshiba Satellite C55-A5310 Fan Replacement: step 8, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement: step 8, image 2 of 2
    • Remove the single .5mm JIS #000 screw.
  9. Toshiba Satellite C55-A5310 Fan Replacement: step 9, image 1 of 1
    • Use the plastic opening tool to remove the keyboard from the laptop.
  10. Toshiba Satellite C55-A5310 Fan Replacement: step 10, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement: step 10, image 2 of 2
    • Once the keyboard is popped out, use a spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
  11. Toshiba Satellite C55-A5310 Fan Replacement: step 11, image 1 of 1
    • Remove thirteen JIS #000 11mm screws.
  12. Toshiba Satellite C55-A5310 Fan Replacement: step 12, image 1 of 2 Toshiba Satellite C55-A5310 Fan Replacement: step 12, image 2 of 2
    • Use a nylon spudger tool to lift up on all sides.
    • Once the panel has been loosened it will pop off.
  13. Toshiba Satellite C55-A5310 Fan Replacement: step 13, image 1 of 1
    • Remove five 11mm JIS #000 screws.
  14. Toshiba Satellite C55-A5310 Fan Replacement: step 14, image 1 of 3 Toshiba Satellite C55-A5310 Fan Replacement: step 14, image 2 of 3 Toshiba Satellite C55-A5310 Fan Replacement: step 14, image 3 of 3
    • Remove the four wires with tweezers.
    • Remove wires gently to avoid damaging them.
  15. Toshiba Satellite C55-A5310 Fan Replacement: step 15, image 1 of 1
    • Lift from corresponding sides of the fan and it'll pop right out.
Robin
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 13
All Time: 554
