Toshiba Satellite C55-A5302 Keyboard Replacement
  1. Toshiba Satellite C55-A5302 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Power down the laptop and remove all power cords. After this is done, turn the laptop over.
  2. Toshiba Satellite C55-A5302 Keyboard Replacement: step 2, image 1 of 1
    • Slide the battery latches outwards away from the center of the device.
    • The right latch will slide to the right, and left latch to the left.
  3. Toshiba Satellite C55-A5302 Keyboard Replacement: step 3, image 1 of 1
    • Lift and remove the battery from the device.
  4. Toshiba Satellite C55-A5302 Keyboard Replacement, Hard Drive: step 4, image 1 of 1
    • Use the Phillips #1 screwdriver to unscrew the thirteen screws on the back of your device.
  5. Toshiba Satellite C55-A5302 Keyboard Replacement: step 5, image 1 of 1
    • Remove the middle plastic cover to expose the hard drive.
  6. Toshiba Satellite C55-A5302 Keyboard Replacement: step 6, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the two screws holding the hard drive in place.
  7. Toshiba Satellite C55-A5302 Keyboard Replacement: step 7, image 1 of 1
    • Remove the three screws using the Phillips #1 screwdriver.
    • Insert you fingers into the rubber ends and gently pull the hard drive out of the device.
  8. Toshiba Satellite C55-A5302 Keyboard Replacement, Optical Disk Drive: step 8, image 1 of 1
    • Use the Phillips #1 screwdriver to remove the two screws under the hard drive.
  9. Toshiba Satellite C55-A5302 Keyboard Replacement: step 9, image 1 of 1
    • Use a metal spudger and run it along the edges of the computer to take off the plastic back cover. (Starting near a port usually allows more space for the spudger to be inserted)
  10. Toshiba Satellite C55-A5302 Keyboard Replacement: step 10, image 1 of 1
    • Slowly work from one end to the other to lift the back cover off.
  11. Toshiba Satellite C55-A5302 Keyboard Replacement: step 11, image 1 of 2 Toshiba Satellite C55-A5302 Keyboard Replacement: step 11, image 2 of 2
    • Grab hold of the optical drive and elevate it slightly and remove it from the computer.
  12. Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: step 12, image 1 of 2 Toshiba Satellite C55-A5302 Keyboard Replacement, Keyboard: step 12, image 2 of 2
    • Using your thumb, apply a light amount of pressure to the underside of the keyboard until it pops out a bit.
  13. Toshiba Satellite C55-A5302 Keyboard Replacement: step 13, image 1 of 1
    • Using the metal spudger, carefully pry up the edges of the keyboard.
  14. Toshiba Satellite C55-A5302 Keyboard Replacement: step 14, image 1 of 1
    • Shift the small tabs on either side of the ribbon outwards to release the end of the ribbon.
    • Gently remove the keyboard from the device.
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 472
