Toshiba Satellite C55-A5100 RAM Replacement
  1. Toshiba Satellite C55-A5100 RAM Replacement, Battery: step 1, image 1 of 1
    • Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
  2. Toshiba Satellite C55-A5100 RAM Replacement: step 2, image 1 of 1
    • Lift the battery upward with your fingers out of the battery compartment.
  3. Toshiba Satellite C55-A5100 RAM Replacement, RAM: step 3, image 1 of 1
    • Place the laptop with the bottom facing up.
    • Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
  4. Toshiba Satellite C55-A5100 RAM Replacement: step 4, image 1 of 2 Toshiba Satellite C55-A5100 RAM Replacement: step 4, image 2 of 2
    • Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
  5. Toshiba Satellite C55-A5100 RAM Replacement: step 5, image 1 of 1
    • Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
  6. Toshiba Satellite C55-A5100 RAM Replacement: step 6, image 1 of 1
    • The ram chip will tilt up after the clips are released.
    • Using your fingers, pull the ram chip out at a slight angle.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 348
