Toshiba Qosmio X775-3DV80 RAM Replacement
  1. Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: step 1, image 1 of 2 Toshiba Qosmio X775-3DV80 RAM Replacement, Battery: step 1, image 2 of 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 RAM Replacement: step 2, image 1 of 2 Toshiba Qosmio X775-3DV80 RAM Replacement: step 2, image 2 of 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 RAM Replacement: step 3, image 1 of 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 RAM Replacement, RAM: step 4, image 1 of 1
    • Loosen the single screw on the service panel by twisting counterclockwise with a Phillips #00 screwdriver.
    • It is a captive screw that will remain attached to the service panel.
  5. Toshiba Qosmio X775-3DV80 RAM Replacement: step 5, image 1 of 1
    • Using a spudger or plastic opening tool, pry off the service panel.
  6. Toshiba Qosmio X775-3DV80 RAM Replacement: step 6, image 1 of 3 Toshiba Qosmio X775-3DV80 RAM Replacement: step 6, image 2 of 3 Toshiba Qosmio X775-3DV80 RAM Replacement: step 6, image 3 of 3
    • Using your fingers, pull the retaining clips away from the RAM sticks.
    • Pull the RAM sticks out of the slots.
Jesse Adam Ory
745 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 13
All Time: 386
