Toshiba Qosmio X775-3DV80 Optical Drive Replacement
  1. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: step 1, image 1 of 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • Turn your laptop over so the underside is facing up.
  2. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 2, image 1 of 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 2, image 2 of 2
    • Identify the two sliding locks on either side of the battery.
    • Simultaneously slide both locks outward to release the battery.
  3. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 3, image 1 of 1
    • Pull the battery straight out of its slot to remove it.
  4. Toshiba Qosmio X775-3DV80 Optical Drive Replacement, Optical Drive: step 4, image 1 of 1
    • Locate the optical drive retaining screw on the underside of the laptop.
  5. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 5, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the optical drive retaining screw.
  6. Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 6, image 1 of 2 Toshiba Qosmio X775-3DV80 Optical Drive Replacement: step 6, image 2 of 2
    • Using your finger or a spudger, push the optical drive out of its compartment so you can grab it.
    • Pull the optical drive out of its slot in the side of the laptop.
Jesse Adam Ory
745 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 290
