Toshiba Qosmio X505-Q860 RAM Replacement
  1. Toshiba Qosmio X505-Q860 RAM Replacement, Battery: step 1, image 1 of 3 Toshiba Qosmio X505-Q860 RAM Replacement, Battery: step 1, image 2 of 3 Toshiba Qosmio X505-Q860 RAM Replacement, Battery: step 1, image 3 of 3
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 RAM Replacement: step 2, image 1 of 3 Toshiba Qosmio X505-Q860 RAM Replacement: step 2, image 2 of 3 Toshiba Qosmio X505-Q860 RAM Replacement: step 2, image 3 of 3
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 RAM Replacement, RAM: step 3, image 1 of 3 Toshiba Qosmio X505-Q860 RAM Replacement, RAM: step 3, image 2 of 3 Toshiba Qosmio X505-Q860 RAM Replacement, RAM: step 3, image 3 of 3
    • Use a JIS #0 screwdriver to remove the three 4.8mm long screws that secure the RAM cover.
    • Lift the cover off using the indent for leverage.
  4. Toshiba Qosmio X505-Q860 RAM Replacement: step 4, image 1 of 2 Toshiba Qosmio X505-Q860 RAM Replacement: step 4, image 2 of 2
    • Use a spudger or your fingers to push the RAM brackets outwards until the RAM pops up.
    • Once the RAM stick is angled up, pull it out along the angle.
    • Repeat this step for the lower ram card.
One Comment
How do I bypass the enter password
Richard - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 382
