Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement
  1. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: step 1, image 1 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: step 1, image 2 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Battery: step 1, image 3 of 3
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 2, image 1 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 2, image 2 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 2, image 3 of 3
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: step 3, image 1 of 2 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive Cover Panel: step 3, image 2 of 2
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
  4. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: step 4, image 1 of 2 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement, Hard Disk Drive: step 4, image 2 of 2
    • Use the JIS screwdriver head to remove the 3.7mm long JIS #0 screws at the base of the hard drive.
  5. Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 5, image 1 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 5, image 2 of 3 Toshiba Qosmio X505-Q860 Hard Disk Drive Replacement: step 5, image 3 of 3
    • Next, use the pull tab to pull down and detach the hard drive from the connector.
    • Now the hard drive is loose and can be lifted straight out of the laptop.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 1,193
