Toshiba Qosmio X505-Q860 CD Drive Replacement
  1. Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: step 1, image 1 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: step 1, image 2 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement, Battery: step 1, image 3 of 3
    • Turn off laptop before starting.
    • Flip the switch on the right to the unlocked position.
  2. Toshiba Qosmio X505-Q860 CD Drive Replacement: step 2, image 1 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement: step 2, image 2 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement: step 2, image 3 of 3
    • Hold the switch on the left and pull the battery up towards you, using the marked tab, to take it out.
  3. Toshiba Qosmio X505-Q860 CD Drive Replacement, Hard Disk Drive Cover Panel: step 3, image 1 of 2 Toshiba Qosmio X505-Q860 CD Drive Replacement, Hard Disk Drive Cover Panel: step 3, image 2 of 2
    • Use a JIS #0 screwdriver to unscrew the two 4.6 mm screws at the base of the casing.
    • Pull off the part of the case that's now loose by the indicated tab.
  4. Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: step 4, image 1 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: step 4, image 2 of 3 Toshiba Qosmio X505-Q860 CD Drive Replacement, CD Drive: step 4, image 3 of 3
    • Take out the 4.7mm long JIS #0 screw with a JIS Screwdriver.
    • The CD Drive is now loose. Pull it straight out of the side.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 309
