Toshiba Portege Z835-P330 Internal Cooling Fan Replacement
  1. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement, Internal Cooling Fan: step 1, image 1 of 1
    • Remove the thirteen 1.4mm screws using a Phillips #2 screwdriver.
  2. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: step 2, image 1 of 1
    • Locate hidden screw found in the middle of back hardcover.
    • Here you will find a proprietary Japanese Screw Head.
    • Remove screw by using tool not provided by IFixit or by using the methods found here.
  3. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: step 3, image 1 of 1
    • Peel off hard cover to expose interior of device
  4. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: step 4, image 1 of 1
    • Remove the two 1 mm screws using a Phillips #2 screwdriver.
  5. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: step 5, image 1 of 1
    • Unplug the internal cooling fan by tugging gently on the wire attatched to the device's motherboard
  6. Toshiba Portege Z835-P330 Internal Cooling Fan Replacement: step 6, image 1 of 1
    • Lift the internal cooling fan to remove the fan from the device
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 574
