Toshiba Portege R835-P56X Speaker Replacement
  1. Toshiba Portege R835-P56X Speaker Replacement, Speaker: step 1, image 1 of 1
    • Turn laptop with the back cover facing up .
    • Make sure the laptop is unplugged and powered off before beginning.
  2. Toshiba Portege R835-P56X Speaker Replacement: step 2, image 1 of 2 Toshiba Portege R835-P56X Speaker Replacement: step 2, image 2 of 2
    • Unlock the clips by pulling towards the unlock.
  3. Toshiba Portege R835-P56X Speaker Replacement: step 3, image 1 of 3 Toshiba Portege R835-P56X Speaker Replacement: step 3, image 2 of 3 Toshiba Portege R835-P56X Speaker Replacement: step 3, image 3 of 3
    • Holding the unlock clips push the battery away from the laptop.
  4. Toshiba Portege R835-P56X Speaker Replacement: step 4, image 1 of 1
    • Remove the screws from the back of the laptop
    • you should have removed 18 screws, make sure to keep these in a safe place as you will need them for reassembly.
  5. Toshiba Portege R835-P56X Speaker Replacement: step 5, image 1 of 2 Toshiba Portege R835-P56X Speaker Replacement: step 5, image 2 of 2
    • Using the blue prying plastic tool remove the back cover.
  6. Toshiba Portege R835-P56X Speaker Replacement: step 6, image 1 of 1
    • Remove the screws from the fan and side ports
  7. Toshiba Portege R835-P56X Speaker Replacement: step 7, image 1 of 3 Toshiba Portege R835-P56X Speaker Replacement: step 7, image 2 of 3 Toshiba Portege R835-P56X Speaker Replacement: step 7, image 3 of 3
    • Remove the white and orange cables attached by pulling out the cables
  8. Toshiba Portege R835-P56X Speaker Replacement: step 8, image 1 of 2 Toshiba Portege R835-P56X Speaker Replacement: step 8, image 2 of 2
    • locate the speakers
    • Gently lift the motherboard to release the speaker cables
  9. Toshiba Portege R835-P56X Speaker Replacement: step 9, image 1 of 2 Toshiba Portege R835-P56X Speaker Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, gently remove the tape being used to hold down the speaker cables.
  10. Toshiba Portege R835-P56X Speaker Replacement: step 10, image 1 of 2 Toshiba Portege R835-P56X Speaker Replacement: step 10, image 2 of 2
    • Once the cable had been released you have successfully removed the speakers!
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 389
