Toshiba Portege R835-P56X Screen Replacement
  1. Toshiba Portege R835-P56X Screen Replacement, Battery: step 1, image 1 of 1
    • Place the laptop with the battery facing up.
    • Make sure the laptop is powered off and unplugged.
  2. Toshiba Portege R835-P56X Screen Replacement: step 2, image 1 of 2 Toshiba Portege R835-P56X Screen Replacement: step 2, image 2 of 2
    • Unlock the clips by pulling towards the open lock.
  3. Toshiba Portege R835-P56X Screen Replacement: step 3, image 1 of 3 Toshiba Portege R835-P56X Screen Replacement: step 3, image 2 of 3 Toshiba Portege R835-P56X Screen Replacement: step 3, image 3 of 3
    • Hold the unlock clip while pulling the battery away from the laptop.
  4. Toshiba Portege R835-P56X Screen Replacement, Screen: step 4, image 1 of 3 Toshiba Portege R835-P56X Screen Replacement, Screen: step 4, image 2 of 3 Toshiba Portege R835-P56X Screen Replacement, Screen: step 4, image 3 of 3
    • Use the screwdriver to unscrew 18 screws.
    • Remove the back cover of the laptop.
  5. Toshiba Portege R835-P56X Screen Replacement: step 5, image 1 of 1
    • Remove the screw from the metal hinges in the top corners of the laptop as shown in the picture.
  6. Toshiba Portege R835-P56X Screen Replacement: step 6, image 1 of 1
    • Disconnect the white plug with red and black wires located on the right-most upper corner with the chrome hinges pointed farthest away from you.
  7. Toshiba Portege R835-P56X Screen Replacement: step 7, image 1 of 2 Toshiba Portege R835-P56X Screen Replacement: step 7, image 2 of 2
    • Remove the chrome hinges using the blue prying tool. The hinges should pop right off without must effort.
  8. Toshiba Portege R835-P56X Screen Replacement: step 8, image 1 of 1
    • Remove the screws located underneath the hinges.
  9. Toshiba Portege R835-P56X Screen Replacement: step 9, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers, remove the plastic caps from the top edge of the laptop screen, located near the front-facing camera. All but the cap closest to the camera should be removed.
  10. Toshiba Portege R835-P56X Screen Replacement: step 10, image 1 of 1
    • Remove the screws located underneath the plastic caps.
  11. Toshiba Portege R835-P56X Screen Replacement: step 11, image 1 of 1
    • Snap the laptop screen casing off.
  12. Toshiba Portege R835-P56X Screen Replacement: step 12, image 1 of 2 Toshiba Portege R835-P56X Screen Replacement: step 12, image 2 of 2
    • Disconnect the grey mesh wire from underneath the unattached laptop screen.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 569
