Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement
  1. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: step 1, image 1 of 2 Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement, DVD Drive: step 1, image 2 of 2
    • Turn the DVD player upside down.
    • Slide the lock switch to the side.
    • Slide the battery pack toward the lock switch and off of the back case.
  2. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 2, image 1 of 1
    • Remove the following twelve screws:
    • Ten 7 mm Phillips #00 screws
    • Two 8 mm Phillips #00 screws
  3. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 3, image 1 of 1
    • Use your fingers to pull the back case away from the body of the DVD player.
    • Remove the back case.
  4. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 4, image 1 of 1
    • Use your fingers to pull off the plastic sheet.
  5. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 5, image 1 of 1
    • Remove the following screw:
    • One 2 mm Phillips #00 screw
    • Detach the gray wire.
  6. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 6, image 1 of 1
    • Disconnect the ribbon cable by pulling it straight out of the connector.
  7. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 7, image 1 of 1
    • Remove the following five screws:
    • Three 4 mm Phillips #00 screws
    • Two 2 mm Phillips #00 screws
  8. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 8, image 1 of 1
    • Remove three rubber stoppers.
  9. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 9, image 1 of 1
    • Remove the following screws:
    • Two 4mm Phillips #00 screws
  10. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 10, image 1 of 1
    • Use your fingers to pry the motherboard away from the upper case so you can access the DVD drive wires.
  11. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 11, image 1 of 1
    • Flip the DVD player over to access the drive wires.
    • Pull the bundled cable away from the connector in the same direction the individual wires are running.
  12. Toshiba Portable DVD Player SD-P1700 DVD Drive Replacement: step 12, image 1 of 1
    • Remove all of the DVD drive components from the case.
Katarina Howald
205 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 359
