Toshiba NB255-N250 Memory Replacement
  1. Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: step 1, image 1 of 2 Toshiba NB255-N250 Memory Replacement, Power off the Toshiba NB255-N250: step 1, image 2 of 2
    • Before starting any repairs, make sure to power off your device.
    • To shut down the Toshiba NB255-N250, follow the instructions for your operating system or press and hold the power button until the screen turns off.
  2. Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 1 of 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 2 of 3 Toshiba NB255-N250 Memory Replacement, Remove the Battery: step 2, image 3 of 3
    • Move the two battery retaining tabs to the opposite sides of the device, then pull the battery straight out the back of the device.
  3. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel Screw: step 3, image 1 of 1
    • Remove the PH1 screw from the memory access panel.
    • Unlike many other access cover screws on laptops, this screw is not captive.
  4. Toshiba NB255-N250 Memory Replacement, Remove The Memory Access Panel: step 4, image 1 of 1
    • Use a Metal Spudger or other opening tool to remove the memory access panel.
  5. Toshiba NB255-N250 Memory Replacement, Remove Old Memory: step 5, image 1 of 2 Toshiba NB255-N250 Memory Replacement, Remove Old Memory: step 5, image 2 of 2
    • Remove the memory by moving the tabs on the left and right away from the ram.
    • When fully opened, the memory will pop up at a 45 degree angle. Pull the memory straight out by the sides and away from the system.
2 other people completed this guide.
Charles Myrick
270 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 16
All Time: 347
