Toshiba NB205 N330PK Speaker Removal
  1. Toshiba NB205 N330PK Speaker Removal, Power Button: step 1, image 1 of 2 Toshiba NB205 N330PK Speaker Removal, Power Button: step 1, image 2 of 2
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Speaker Removal: step 2, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 2, image 2 of 2
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Speaker Removal: step 3, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 3, image 2 of 2
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Speaker Removal: step 4, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 4, image 2 of 2
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Speaker Removal, Speaker: step 5, image 1 of 3 Toshiba NB205 N330PK Speaker Removal, Speaker: step 5, image 2 of 3 Toshiba NB205 N330PK Speaker Removal, Speaker: step 5, image 3 of 3
    • Use the spudger to gently pry around the seam of the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Speaker Removal: step 6, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 6, image 2 of 2
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the keyboard assembly out and away from the netbook.
  7. Toshiba NB205 N330PK Speaker Removal: step 7, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 7, image 2 of 2
    • Remove the two noted screws, 5 mm in length, with a bit driver and Phillips 3/16" tool.
  8. Toshiba NB205 N330PK Speaker Removal: step 8, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 8, image 2 of 2
    • Pull the cable away from the connector in the same direction as the individual wires using your hands or tweezers.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use a spudger to gently pry the bezel from retaining clips.
    • This will allow the keyboard bezel to lift off of the body.
  9. Toshiba NB205 N330PK Speaker Removal: step 9, image 1 of 1
    • Use the pointed tip of a spudger to carefully push on each side of the speaker connector to release it. Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
  10. Toshiba NB205 N330PK Speaker Removal: step 10, image 1 of 2 Toshiba NB205 N330PK Speaker Removal: step 10, image 2 of 2
    • Use Phillips #0 screwdriver to remove the two retaining screws on the speaker assembly.
    • Lift out the old speaker assembly.
Mason McCaskill
1,000 Reputation
9 Guides authored
Clemson, Team 14-2, Benson Fall 2013 Member of Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 11
All Time: 564
