Toshiba NB205 N330PK Keyboard Replacement
  1. Toshiba NB205 N330PK Keyboard Replacement, Power Button: step 1, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement, Power Button: step 1, image 2 of 2
    • Start by first removing the battery.
    • Move the first release switch to the right position.
    • Move the second release switch to the right position while pulling the battery towards the top of the netbook.
  2. Toshiba NB205 N330PK Keyboard Replacement: step 2, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement: step 2, image 2 of 2
    • Using the bit driver and a Phillips #0 bit, remove the three circled screws, 5 mm in length.
    • Using the bit driver and a Phillips #0 Bit, remove the two circled screws labelled F6. (These hold the keyboard) one screw may be under a rubber stopper
  3. Toshiba NB205 N330PK Keyboard Replacement: step 3, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement: step 3, image 2 of 2
    • While holding the top of the netbook, flip the netbook over.
  4. Toshiba NB205 N330PK Keyboard Replacement: step 4, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement: step 4, image 2 of 2
    • Carefully lift off the power bar assembly for access to the button and receiver.
  5. Toshiba NB205 N330PK Keyboard Replacement, Keyboard: step 5, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement, Keyboard: step 5, image 2 of 2
    • Use the spudger to gently pry around the keyboard. This will release the keyboard assembly from the body.
  6. Toshiba NB205 N330PK Keyboard Replacement: step 6, image 1 of 2 Toshiba NB205 N330PK Keyboard Replacement: step 6, image 2 of 2
    • Reach under the keyboard and disconnect the electrical connection.
    • Lift the broken keyboard off.
  7. Toshiba NB205 N330PK Keyboard Replacement: step 7, image 1 of 3 Toshiba NB205 N330PK Keyboard Replacement: step 7, image 2 of 3 Toshiba NB205 N330PK Keyboard Replacement: step 7, image 3 of 3
    • Reattach the new electrical connection into the old connection location.
    • Place the keyboard into the original location starting with the bottom first.
    • Gently press the keyboard down to secure it into its original location.
Finish Line
Mason McCaskill
1,000 Reputation
9 Guides authored
Clemson, Team 14-2, Benson Fall 2013 Member of Clemson, Team 14-2, Benson Fall 2013
CLEM-BENSON-F13S14G2
3 Members
27 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 12
All Time: 844
