Toshiba Mini NB505 WiFi Card Replacement
  1. Toshiba Mini NB505 WiFi Card Replacement, Bottom Plate: step 1, image 1 of 1
    • Locate the two 1.2mm philips #000 screws holding the bottom plate onto the laptop.
  2. Toshiba Mini NB505 WiFi Card Replacement: step 2, image 1 of 1
    • Using a Philips head #000 screwdriver, carefully remove the two 1.2mm screws.
  3. Toshiba Mini NB505 WiFi Card Replacement: step 3, image 1 of 1
    • The plate can now be easily removed.
  4. Toshiba Mini NB505 WiFi Card Replacement, WiFi Card: step 4, image 1 of 1
    • Locate the WiFi card by following the black and white wiring inside of the laptop.
  5. Toshiba Mini NB505 WiFi Card Replacement: step 5, image 1 of 2 Toshiba Mini NB505 WiFi Card Replacement: step 5, image 2 of 2
    • Locate and gently pull up on the black and white wires connecting to the card.
  6. Toshiba Mini NB505 WiFi Card Replacement: step 6, image 1 of 1
    • Locate the two 1.2 mm phillips #000 screws holding the WiFi card.
  7. Toshiba Mini NB505 WiFi Card Replacement: step 7, image 1 of 1
    • Use a Phillips head #000 screwdriver to remove the two 1.2mm screws holding the card into the laptop.
  8. Toshiba Mini NB505 WiFi Card Replacement: step 8, image 1 of 1
    • Once the card pops up, gentle remove it.
3 other people completed this guide.
Owen Velho
508 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 17
All Time: 903
