Toshiba HD-A2 Power Button Replacement
  1. Toshiba HD-A2 Power Button Replacement, Power Button: step 1, image 1 of 3 Toshiba HD-A2 Power Button Replacement, Power Button: step 1, image 2 of 3 Toshiba HD-A2 Power Button Replacement, Power Button: step 1, image 3 of 3
    • Using your hands, pop off the black console from each hinge surrounding the case.
    • There are a total of 7 hinges.
  2. Toshiba HD-A2 Power Button Replacement: step 2, image 1 of 1
    • With the inside of the console facing up, the power button will be encased in clear plastic located on the right side of the console.
  3. Toshiba HD-A2 Power Button Replacement: step 3, image 1 of 2 Toshiba HD-A2 Power Button Replacement: step 3, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the single screw holding the power button to the console.
    • After taking out the screw, the small piece of metal underneath will come loose. Carefully place this part aside.
  4. Toshiba HD-A2 Power Button Replacement: step 4, image 1 of 1
    • Using your fingers, gently pull out the power button. You can push it from the outside to help loosen it from its hinges.
Nouriyah Saleh
800 Reputation
6 Guides authored
UC Davis, Team S11-G1, Lore Fall 2018 Member of UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 9
All Time: 152
