Toshiba HD-A2 Optical Drive Replacement
  1. Toshiba HD-A2 Optical Drive Replacement, Top Panel: step 1, image 1 of 1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Optical Drive Replacement: step 2, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 2, image 2 of 2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Optical Drive Replacement: step 3, image 1 of 1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Optical Drive Replacement, Optical Drive: step 4, image 1 of 3 Toshiba HD-A2 Optical Drive Replacement, Optical Drive: step 4, image 2 of 3 Toshiba HD-A2 Optical Drive Replacement, Optical Drive: step 4, image 3 of 3
    • Remove five 6mm Phillips screws with a Phillips #2 screwdriver.
    • The 2 screws on the right of the cartridge are better shown in the second and third photos.
  5. Toshiba HD-A2 Optical Drive Replacement: step 5, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 5, image 2 of 2
    • Remove the remaining four 6mm Phillips screws.
  6. Toshiba HD-A2 Optical Drive Replacement: step 6, image 1 of 3 Toshiba HD-A2 Optical Drive Replacement: step 6, image 2 of 3 Toshiba HD-A2 Optical Drive Replacement: step 6, image 3 of 3
    • Using your fingers, gently remove the metal pieces on each side of the cartridge and carefully place them aside.
  7. Toshiba HD-A2 Optical Drive Replacement: step 7, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 7, image 2 of 2
    • Gently lift the cartridge. Remove two 4mm Phillips screws from the green circuit board.
  8. Toshiba HD-A2 Optical Drive Replacement: step 8, image 1 of 1
    • Using your fingers, gently pull off the wires.
  9. Toshiba HD-A2 Optical Drive Replacement: step 9, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 9, image 2 of 2
    • Using your fingers, pull off the green circuit board from the cartridge and carefully place it down.
    • Be careful not to rip the tape attaching the green circuit boards together.
  10. Toshiba HD-A2 Optical Drive Replacement: step 10, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 10, image 2 of 2
    • Flip the cartridge over to the bare side with no stickers. Remove four 10mm Phillips screws from each corner.
  11. Toshiba HD-A2 Optical Drive Replacement: step 11, image 1 of 2 Toshiba HD-A2 Optical Drive Replacement: step 11, image 2 of 2
    • Using your hands, gently lift the lid and carefully place it aside.
  12. Toshiba HD-A2 Optical Drive Replacement: step 12, image 1 of 3 Toshiba HD-A2 Optical Drive Replacement: step 12, image 2 of 3 Toshiba HD-A2 Optical Drive Replacement: step 12, image 3 of 3
    • Flip over the cartridge. Using your hands, gently lift the rest of the silver case.
Finish Line
Nouriyah Saleh
800 Reputation
6 Guides authored
UC Davis, Team S11-G1, Lore Fall 2018 Member of UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 404
