Toshiba HD-A2 Fan Replacement
  1. Toshiba HD-A2 Fan Replacement, Top Panel: step 1, image 1 of 1
    • Remove the three 6mm Phillips head screws on the back of the DVD player with a Phillips #1 screwdriver.
  2. Toshiba HD-A2 Fan Replacement: step 2, image 1 of 2 Toshiba HD-A2 Fan Replacement: step 2, image 2 of 2
    • Remove the two 3mm Phillips screws on each side of the DVD player using the Phillips #1 screwdriver.
  3. Toshiba HD-A2 Fan Replacement: step 3, image 1 of 1
    • Using your hand, gently lift the black top panel and safely place it off to the side.
  4. Toshiba HD-A2 Fan Replacement, Fan: step 4, image 1 of 1
    • The fan will be attached to the case, connected to the yellow circuit board.
  5. Toshiba HD-A2 Fan Replacement: step 5, image 1 of 2 Toshiba HD-A2 Fan Replacement: step 5, image 2 of 2
    • Remove the two 7mm Phillips head screws attaching the fan to the case of the DVD player.
  6. Toshiba HD-A2 Fan Replacement: step 6, image 1 of 2 Toshiba HD-A2 Fan Replacement: step 6, image 2 of 2
    • Use your fingers to unplug the red and black wire from the yellow circuit board to completely remove the fan.
Nouriyah Saleh
800 Reputation
6 Guides authored
UC Davis, Team S11-G1, Lore Fall 2018 Member of UC Davis, Team S11-G1, Lore Fall 2018
UCD-LORE-F18S11G1
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 10
All Time: 319
