Toshiba Excite 7c Motherboard Replacement
  1. Toshiba Excite 7c Motherboard Replacement, Motherboard: step 1, image 1 of 2 Toshiba Excite 7c Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Place an iFixit opening tool in the seam between the screen and back casing.
    • Apply pressure down all four sides to separate the back casing from the screen.
    • Place the tablet face down and carefully remove the back panel.
  2. Toshiba Excite 7c Motherboard Replacement: step 2, image 1 of 2 Toshiba Excite 7c Motherboard Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use a Phillips screwdriver to remove the five 6 mm screws from the motherboard.
    • Use tweezers to gently disconnect the two ribbon cables.
    • Pull straight up to remove the board.
Adam Burdzel
304 Reputation
1 Guide authored
UMass Dartmouth, Team 1-7, Miles Fall 2015 Member of UMass Dartmouth, Team 1-7, Miles Fall 2015
UMASSD-MILES-F15S1G7
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 374
