Toshiba Encore Mini Speakers Replacement
  1. Toshiba Encore Mini Speakers Replacement, Battery: step 1, image 1 of 2 Toshiba Encore Mini Speakers Replacement, Battery: step 1, image 2 of 2
    • To replace the battery, the rear cover must first be removed.
    • Using the flat end of the spudger, gently pry open the back case from the rest of the device.
    • It may be easier to start along one of the long edges and carefully work your way toward the corner, then along the short edge.
  2. Toshiba Encore Mini Speakers Replacement: step 2, image 1 of 1
    • Remove the rear cover and set it aside.
  3. Toshiba Encore Mini Speakers Replacement: step 3, image 1 of 1
    • Carefully remove the electrical tape that holds the battery in place.
  4. Toshiba Encore Mini Speakers Replacement: step 4, image 1 of 2 Toshiba Encore Mini Speakers Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using needle-nose tweezers, gently push the large white wire connector (connected to the black, red and blue wires) out of its housing.
  5. Toshiba Encore Mini Speakers Replacement: step 5, image 1 of 1
    • Gently lift the battery out of the device.
    • Be careful not to pull on the connecting wires.
  6. Toshiba Encore Mini Speakers Replacement, Speakers: step 6, image 1 of 1
    • Use the spudger to pull the speaker wire plug from its socket.
  7. Toshiba Encore Mini Speakers Replacement: step 7, image 1 of 1
    • Carefully use the metal spudger to remove the speaker from the frame of the phone.
    • The speaker is attached with some double-sided adhesive and may be difficult to remove.
Khaled Alsaghayer
101 Reputation
1 Guide authored
IUPUI, Team S5-G5, Wilson Spring 2017 Member of IUPUI, Team S5-G5, Wilson Spring 2017
IUPUI-WILSON-S17S5G5
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 160
