Introduction
The Toshiba Encore Mini is equipped with a built-in front-facing camera and a built-in rear-facing camera. Before replacing either camera, we recommend you back-up any photos (or other data) to an external storage device. Also, you will need a good place to keep track of five very small screws, as you will need them for reassembly.
Using the flat end of the spudger, gently pry open the back case from the rest of the device.
Using needle-nose tweezers, carefully flip up the dark gray cover on the right of the device holding the small orange ribbon in place. (It is approximately 1/4" wide.)
With the tweezers, carefully pull the small ribbon out of its housing. It will stay attached to the device at the other end.
