Toshiba Dynabook AX 53D Keyboard Replacement
  1. Toshiba Dynabook AX 53D Keyboard  Replacement, Battery: step 1, image 1 of 1
    • Push apart the two spring loaded plastic tabs labeled #1 and #2.
    • Make sure to unplug any external power sources before working on the computer.
  2. Toshiba Dynabook AX 53D Keyboard  Replacement: step 2, image 1 of 1
    • The battery is now easily removed by pulling up from the notched tab on the inside edge.
  3. Toshiba Dynabook AX 53D Keyboard  Replacement, Keyboard: step 3, image 1 of 1
    • Using the #J1 bit, remove the 17 recessed 7.3 mm B6 screws from the underside of laptop and the 3.1 mm #J0 F3 screw inside the battery compartment.
  4. Toshiba Dynabook AX 53D Keyboard  Replacement: step 4, image 1 of 2 Toshiba Dynabook AX 53D Keyboard  Replacement: step 4, image 2 of 2
    • Run the blue plastic opening tool underneath the media bezel and gently pry from the front panel.
  5. Toshiba Dynabook AX 53D Keyboard  Replacement: step 5, image 1 of 1
    • Using the #J0 bit, remove the two 3.1 mm screws securing the top of the keyboard.
  6. Toshiba Dynabook AX 53D Keyboard  Replacement: step 6, image 1 of 2 Toshiba Dynabook AX 53D Keyboard  Replacement: step 6, image 2 of 2
    • Pop out the black plastic tab on either side of the ribbon cable. Holding the cable on each side, detach from laptop.
Christopher
510 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 1,036
