Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement
  1. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement, WLAN Wi-Fi PCB: step 1, image 1 of 1
    • Remove the two rubber tabs near the front of the computer with a metal spudger and with PH0 Phillips head screwdriver, carefully remove all ten screws and place in a safe location.
  2. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: step 2, image 1 of 1
    • Ensure that there is no debris, dust, or any other foreign materials blocking the Wi-Fi PCB.
  3. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: step 3, image 1 of 1
    • Carefully peel back the yellow tape by either folding it back or removing it entirely. Use the same PH0 Phillips head screwdriver to remove the single screw that connects the motherboard to the Wi-Fi PCB.
  4. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: step 4, image 1 of 1
    • When the screw has been removed, the board will naturally spring up. Carefully apply light pressure to back the PCB out of its port.
  5. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: step 5, image 1 of 1
    • Disconnect the black wire that is plugged onto the 1 or AUX terminal by simply lightly pulling it from the board.
  6. Toshiba CB35-C3300 Chromebook 2 WLAN Wi-Fi PCB Replacement: step 6, image 1 of 1
    • Disconnect the white wire from the 2 or Main plug by lightly pulling it from the PCB.
Gabriel Bryan
303 Reputation
2 Guides authored
IUPUI, Team S6-G6, Wilson Fall 2018 Member of IUPUI, Team S6-G6, Wilson Fall 2018
IUPUI-WILSON-F18S6G6
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 157
