Toshiba A1304T Keypad Replacement
  1. Toshiba A1304T Keypad Replacement, Back panel: step 1, image 1 of 1
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. Toshiba A1304T Keypad Replacement: step 2, image 1 of 1
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. Toshiba A1304T Keypad Replacement: step 3, image 1 of 2 Toshiba A1304T Keypad Replacement: step 3, image 2 of 2
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
  4. Toshiba A1304T Keypad Replacement, Keypad: step 4, image 1 of 3 Toshiba A1304T Keypad Replacement, Keypad: step 4, image 2 of 3 Toshiba A1304T Keypad Replacement, Keypad: step 4, image 3 of 3
    • Use your fingers to detach the ribbon wire located on the top of the logic board, as shown.
  5. Toshiba A1304T Keypad Replacement: step 5, image 1 of 2 Toshiba A1304T Keypad Replacement: step 5, image 2 of 2
    • Use a flathead screwdriver to gently pry the logic board and keypad from the device.
  6. Toshiba A1304T Keypad Replacement: step 6, image 1 of 2 Toshiba A1304T Keypad Replacement: step 6, image 2 of 2
    • Peel the keypad from the logic board using your thumb.
Christopher
90 Reputation
8 Guides authored
Cal Poly, Team 16-6, Maness Spring 2010 Member of Cal Poly, Team 16-6, Maness Spring 2010
CPSU-MANESS-S10S16G6
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 1,665
