TomTom One XL Power Button Replacement
  1. TomTom One XL Power Button Replacement, Back Panel: step 1, image 1 of 2 TomTom One XL Power Button Replacement, Back Panel: step 1, image 2 of 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Power Button Replacement: step 2, image 1 of 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Power Button Replacement: step 3, image 1 of 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Power Button Replacement: step 4, image 1 of 2 TomTom One XL Power Button Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Power Button Replacement, Power Button: step 5, image 1 of 1
    • Using a Torx 6 screwdriver, remove the 4 .5mm screws connecting the motherboard to the screen assembly.
    • The motherboard is connected to the screen assembly via a ribbon wire. After removing the screws, be careful not to damage the wire or the port.
  6. TomTom One XL Power Button Replacement: step 6, image 1 of 2 TomTom One XL Power Button Replacement: step 6, image 2 of 2
    • Detach the ribbon wire from it's port on the back of the motherboard.
  7. TomTom One XL Power Button Replacement: step 7, image 1 of 3 TomTom One XL Power Button Replacement: step 7, image 2 of 3 TomTom One XL Power Button Replacement: step 7, image 3 of 3
    • Now the power button is exposed and any obstructions can be easily removed.
    • If you want to replace the button it can easily be popped out using your hands.
Jesse
101 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 20
All Time: 2,205
