TomTom One XL Battery Replacement
  1. TomTom One XL Battery Replacement, Back Panel: step 1, image 1 of 2 TomTom One XL Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove the 4 .4mm screws on the back of the device.
  2. TomTom One XL Battery Replacement: step 2, image 1 of 1
    • Using the palate knife tool, pry the back from the LCD screen. Apply a moderate pressure to separate them.
    • You can rotate TOMTOM XL to make prying back off easier.
    • Be careful not to injure the two wires connecting the pieces.
  3. TomTom One XL Battery Replacement: step 3, image 1 of 1
    • After prying both halves apart, they will be connected by two wires.
    • Carefully set the two halves next to each other making sure not to stress or damage the wires.
  4. TomTom One XL Battery Replacement: step 4, image 1 of 2 TomTom One XL Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers separate the wires connecting the battery and speaker to the mother board.
    • Be gentle while pulling the wires out, the plugs are easily injured.
  5. TomTom One XL Battery Replacement, Battery: step 5, image 1 of 1
    • Using metal palate knife pry the battery from the back panel.
  6. TomTom One XL Battery Replacement: step 6, image 1 of 3 TomTom One XL Battery Replacement: step 6, image 2 of 3 TomTom One XL Battery Replacement: step 6, image 3 of 3
    • Place the backside of the battery on the sticky side of the double sided tape.
    • Using the tech knife, trim the extra tape to the size of the battery.
    • The tech knife is sharp, be careful when cutting the tape.
  7. TomTom One XL Battery Replacement: step 7, image 1 of 3 TomTom One XL Battery Replacement: step 7, image 2 of 3 TomTom One XL Battery Replacement: step 7, image 3 of 3
    • Remove the back of the double sided tap.
    • Place the new battery back inside the back panel of TOMTOM XL.
    • Make sure the wire from the battery is going in the correct direction.
  8. TomTom One XL Battery Replacement: step 8, image 1 of 3 TomTom One XL Battery Replacement: step 8, image 2 of 3 TomTom One XL Battery Replacement: step 8, image 3 of 3
    • Reconnect the battery ribbon cable to its port.
DeVhan
401 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 1,464
