Titan Airless Sprayer IMPACT 410 Capacitor Replacement
  1. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: step 1, image 1 of 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Safety precautions: step 1, image 2 of 2
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before powering down the paint sprayer and disconnecting the pump.
    • Turn off and unplug the sprayer.
  2. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: step 2, image 1 of 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Unfasten the motor cover: step 2, image 2 of 2
    • Use a Phillips driver to remove the four 12 mm-long screws (two on either side) securing the motor cover.
  3. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: step 3, image 1 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: step 3, image 2 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the motor cover: step 3, image 3 of 3
    • Pull the motor cover straight off the motor.
  4. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: step 4, image 1 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: step 4, image 2 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor wires: step 4, image 3 of 3
    • Use diagonal cutters, or scissors, to cut the two cable ties bundling the capacitor's positive and negative wires.
    • During reassembly, replace the cable ties.
  5. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: step 5, image 1 of 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the negative wire: step 5, image 2 of 2
    • Disconnect the black negative wire's spade connector.
    • Always grip cables by their connectors and not the wires themselves.
  6. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: step 6, image 1 of 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Disconnect the positive wire: step 6, image 2 of 2
    • Disconnect the red positive wire's bullet connector.
  7. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: step 7, image 1 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: step 7, image 2 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Isolate the capacitor: step 7, image 3 of 3
    • Grip the cable tie and slide it off the capacitors.
  8. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Discharge the capacitors: step 8, image 1 of 1
    • If you have already discharged the capacitors, skip this step.
    • Follow this guide to discharge your capacitors.
  9. Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: step 9, image 1 of 2 Titan Airless Sprayer IMPACT 410 Capacitor Replacement, Remove the capacitors: step 9, image 2 of 2
    • The capacitors are lightly adhered to the motor body.
    • Insert a flathead screwdriver underneath the capacitors, between the bottom cell and the adhesive.
    • Pry up to separate the bottom cell from the motor body.
  10. Titan Airless Sprayer IMPACT 410 Capacitor Replacement: step 10, image 1 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: step 10, image 2 of 3 Titan Airless Sprayer IMPACT 410 Capacitor Replacement: step 10, image 3 of 3
    • Insert a flathead screwdriver underneath the capacitors, between the top cell and the adhesive.
    • Pry up to separate the rest of the capacitor from the motor body.
    • Remove the capacitor.
    • During reassembly, if the adhesive is no longer sticky, replace it with double-sided foam adhesive.
Alex Diaz-Kokaisl
124,999 Reputation
582 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,419 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 14
All Time: 293
