Tascam Portastudio 05 Broken Play Switch
  1. Tascam Portastudio 05 Broken Play Switch, Tascam Portastudio 05 Broken Play Switch: step 1, image 1 of 3 Tascam Portastudio 05 Broken Play Switch, Tascam Portastudio 05 Broken Play Switch: step 1, image 2 of 3 Tascam Portastudio 05 Broken Play Switch, Tascam Portastudio 05 Broken Play Switch: step 1, image 3 of 3
    • Remove the power buton
    • Remove the screws from back
    • Gently open the device
  2. Tascam Portastudio 05 Broken Play Switch: step 2, image 1 of 3 Tascam Portastudio 05 Broken Play Switch: step 2, image 2 of 3 Tascam Portastudio 05 Broken Play Switch: step 2, image 3 of 3
    • Remove this screws
    • The PLAY doesn't work because the plastic is broken. It holds a spring.
    • Gluing the plastic will not work, as spring pressure is too high.
  3. Tascam Portastudio 05 Broken Play Switch: step 3, image 1 of 3 Tascam Portastudio 05 Broken Play Switch: step 3, image 2 of 3 Tascam Portastudio 05 Broken Play Switch: step 3, image 3 of 3
    • To make a good support for the spring, drill a hole on the metal and ADD a little screw.
  4. Tascam Portastudio 05 Broken Play Switch: step 4, image 1 of 2 Tascam Portastudio 05 Broken Play Switch: step 4, image 2 of 2
    • This little plug has the sound output of the four tracks split. You can add independent outputs from tape.
Para remontagem de seu dispositivo, siga estas instruções na ordem inversa.
Cafony
687 Reputation
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 442
