TOSHIBA Satellite E45W-C4200X RAM Replacement
  1. TOSHIBA Satellite E45W-C4200X RAM Replacement, RAM: step 1, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the ten 1 mm screws on the back panel.
  2. TOSHIBA Satellite E45W-C4200X RAM Replacement: step 2, image 1 of 2 TOSHIBA Satellite E45W-C4200X RAM Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to separate the back panel from the rest of the computer.
    • Be careful and do not to crack the panel.
  3. TOSHIBA Satellite E45W-C4200X RAM Replacement: step 3, image 1 of 2 TOSHIBA Satellite E45W-C4200X RAM Replacement: step 3, image 2 of 2
    • Remove the grey film covering the RAM located on the left side of the computer.
  4. TOSHIBA Satellite E45W-C4200X RAM Replacement: step 4, image 1 of 3 TOSHIBA Satellite E45W-C4200X RAM Replacement: step 4, image 2 of 3 TOSHIBA Satellite E45W-C4200X RAM Replacement: step 4, image 3 of 3
    • Apply pressure on the inside of both brackets until the RAM chips are released.
    • Repeat this step for RAM Slot B.
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 531
