TOSHIBA Satellite E45W-C4200X Keyboard Replacement
  1. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: step 1, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Cooling Fan: step 1, image 2 of 2
    • Using the phillips #1 screwdriver, remove the ten 1 mm screws from the back panel of the device.
  2. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 2, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 2, image 2 of 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
  3. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 3, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 3, image 2 of 2
    • Remove the four .5 mm screws that secure the heat sink using a Phillips #1 screwdriver.
  4. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 4, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 4, image 2 of 2
    • Remove the two 1 mm screws that secure the cooling fan using a Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 5, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 5, image 2 of 2
    • Disconnect the fan cord from the harness.
    • Remove the cooling fan and heat sink from the laptop.
  6. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 6, image 1 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 6, image 2 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 6, image 3 of 3
    • Carefully peel off the tape holding the heat sink onto the cooling fan.
    • Peel carefully as the tape goes around all four sides.
    • Remove the cooling fan from the heat sink.
  7. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: step 7, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Motherboard: step 7, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Unplug the connection to the battery.
    • Mark sure you are using the anti-static wrist strap for the duration of this replacement.
  8. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 8, image 1 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 8, image 2 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 8, image 3 of 3
    • Remove all remaining external wire harnesses from the circuit board.
    • It is recommended that you use labels or take pictures of the wires you remove to assist in the re-connection.
  9. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 9, image 1 of 1
    • Remove the three screws from the metal bracket on the left side of the circuit board using a Phillips #1 screwdriver.
    • Remove the bracket.
  10. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 10, image 1 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 10, image 2 of 3 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 10, image 3 of 3
    • Remove the two screws from the black plastic cover using a Phillips #1 screwdriver.
    • Remove the black plastic cover.
  11. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 11, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 11, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the remaining two screws holding the circuit board in place.
    • Carefully remove the motherboard from the device.
  12. TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: step 12, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement, Keyboard: step 12, image 2 of 2
    • Remove the two 1 mm screws from the black plastic cover using the Phillips #1 screwdriver.
  13. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 13, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 13, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the three 0.5 mm screws from metal bracket.
  14. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 14, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 14, image 2 of 2
    • Use the Phillips #000 screwdriver to remove the 44 (forty four) 0.5 mm screws on the existing silver panel.
  15. TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 15, image 1 of 2 TOSHIBA Satellite E45W-C4200X Keyboard Replacement: step 15, image 2 of 2
    • Pull up on the black tab that is on the silver panel to remove the keyboard.
2 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 563
