TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement
  1. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: step 1, image 1 of 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement, DC Power Jack: step 1, image 2 of 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillip's #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 2, image 1 of 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 2, image 2 of 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommended that you start from a corner and run the tool along the edge
  3. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 3, image 1 of 2 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 3, image 2 of 2
    • Using a Phillips # 1 screwdriver, remove the three screws holding the bracket over the ports on the right side.
    • Remove the bracket.
  4. TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 4, image 1 of 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 4, image 2 of 3 TOSHIBA Satellite E45W-C4200X DC Power Jack Replacement: step 4, image 3 of 3
    • Unplug the power cable harness from the motherboard.
    • Lift the power jack out of its slot in the top right corner.
    • Remove the cable.
One Comment
Thanks for this. Great help in sorting out my laptop.
Jack - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 582
