TOSHIBA Satellite E45W-C4200X Battery Replacement
  1. TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: step 1, image 1 of 2 TOSHIBA Satellite E45W-C4200X Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the ten 1 mm screws that secure the back cover using a Phillips #1 screwdriver.
  2. TOSHIBA Satellite E45W-C4200X Battery Replacement: step 2, image 1 of 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: step 2, image 2 of 2
    • Use plastic opening tool to separate the back cover from the laptop.
    • Go slowly and be careful as the plastic can crack.
    • It is recommend that you start from a corner and run the tool along the edge.
    • Lift and remove the casing.
  3. TOSHIBA Satellite E45W-C4200X Battery Replacement: step 3, image 1 of 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: step 3, image 2 of 2
    • Gently lift the flap covering the top side of the battery.
  4. TOSHIBA Satellite E45W-C4200X Battery Replacement: step 4, image 1 of 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: step 4, image 2 of 2
    • Remove the four 0.5 mm screws that hold the battery in using the Phillips #1 screwdriver.
  5. TOSHIBA Satellite E45W-C4200X Battery Replacement: step 5, image 1 of 2 TOSHIBA Satellite E45W-C4200X Battery Replacement: step 5, image 2 of 2
    • Unplug the battery from the motherboard.
  6. TOSHIBA Satellite E45W-C4200X Battery Replacement: step 6, image 1 of 1
    • Remove the battery from the laptop.
3 other people completed this guide.
One Comment
My laptop is only working while plugged in i recently changed the battery and the problem persist. Any idea what else it can be ?
Gabriel Meza - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,043
