Sylvania SDVD9004 Screen Replacement
  1. Sylvania SDVD9004 Screen Replacement, Back cover: step 1, image 1 of 1
    • Remove ten 7mm Phillips #0 screws.
    • Remove four 5mm Phillips #0 screws.
  2. Sylvania SDVD9004 Screen Replacement: step 2, image 1 of 2 Sylvania SDVD9004 Screen Replacement: step 2, image 2 of 2
    • Flip the device over.
    • Lift the top.
  3. Sylvania SDVD9004 Screen Replacement: step 3, image 1 of 1
    • This guide uses incorrect tools. Use an ESD safe tool, such as a nylon spudger, to complete this step.
  4. Sylvania SDVD9004 Screen Replacement, Screen: step 4, image 1 of 3 Sylvania SDVD9004 Screen Replacement, Screen: step 4, image 2 of 3 Sylvania SDVD9004 Screen Replacement, Screen: step 4, image 3 of 3
    • Disconnect ribbon
    • Rotate screwdriver to peel sticker from ribbon.
    • Place spudger head behind gray tabs on port.
    • Press outward to disengage tab.
    • Repeat on other side.
    • Slide out ribbon.
  5. Sylvania SDVD9004 Screen Replacement: step 5, image 1 of 2 Sylvania SDVD9004 Screen Replacement: step 5, image 2 of 2
    • Using Philips head screwdriver, remove the two 7 mm screws.
    • Slide off top panel.
Sarah Henry
417 Reputation
4 Guides authored
Baylor, Team 5-10, Williams Fall 2016 Member of Baylor, Team 5-10, Williams Fall 2016
BU-WILLIAMS-F16S5G10
2 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 625
